OctaneRender 2020.1 for Houdini Production build 2020.1.5.0
PaGz
Hello,
This is my first time installing a plugin into Houdini Indie and i don't find how to make it work.
Houdini 18.0.597
Octane_2020.1.5.0_Houdini_18.0.597_vr_Win64
I followed theses instructions:
https://docs.otoy.com/HoudiniH/HoudiniP ... oudini.htm
But nothing appear on the Houdini side...
Please help.
juanjgon
PaGz wrote:Hello,
Houdini 18.0.597
Please help.
Probably the problem comes from a mistake in the houdini.env file configuration. Can you please attach it here to take a look at it? Also, please, let me know the folder where you have the plugin installed in your HD.
PaGz
Hello Juanjo :)
Here is my config.
My folder path where Octane is installed is:
C:\Users\PAG\Documents\houdini18.0\Octane_Render
I tried to attach the houdini.env file but the forum says that the extension env is not allowed so here is a copy of the lines in the houdijni.env file:
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOME = H:\
HOUDINI_NVIDIA_OPTIX_DSO_PATH = C:/Users/PAG/Documents/houdini18.0\optix
PATH = C:/Users/PAG/Documents/houdini18.0/Octane_Render/bin;$PATH
HOUDINI_DSO_ERROR = 2
PaGz
Hello again,
I did search the web and found that video and redone my houdini.env configuration:
https://www.youtube.com/watch?v=lzqI3scor7Y
Now Octane is launching in Houdini and is activated but when i close the option menu Octane says that it cannot save the Octane.prefs file
So i realized that it is because i set the houdini HOME = H: (this is where my .hiplc projects reside and where i want houdini create new projects. And also HQueue will search there)
So now my houdini.env is like that but now when creating new project folder i have to manually browse to my H: drive
But Octane works!
# the environment.
# VAR = VALUE
# VAR = "VALUE"
# VAR =
# Example:
#$HOME = H:\
PATH = "C:\Users\PAG\Documents\houdini18.0\Octane_Render\bin;$PATH"
HOUDINI_PATH = "C:\Users\PAG\Documents\houdini18.0\Octane_Render;&"
juanjgon
Great! But in any case, I think that you should not change the default $HOME folder. You should use Houdini projects to manage your work. https://www.sidefx.com/docs/houdini/basics/project.html
PaGz
Thanks Juanjo :)
I know for the home folder but my C drive is not big enough and i never save any 3d project files on my system drive.
