Hello again,
I did search the web and found that video and redone my houdini.env configuration:
https://www.youtube.com/watch?v=lzqI3scor7Y
Now Octane is launching in Houdini and is activated but when i close the option menu Octane says that it cannot save the Octane.prefs file
So i realized that it is because i set the houdini HOME = H: (this is where my .hiplc projects reside and where i want houdini create new projects. And also HQueue will search there)
So now my houdini.env is like that but now when creating new project folder i have to manually browse to my H: drive
But Octane works!
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
#$HOME = H:\
HOUDINI_NVIDIA_OPTIX_DSO_PATH = C:/Users/PAG/Documents/houdini18.0\optix
PATH = "C:\Users\PAG\Documents\houdini18.0\Octane_Render\bin;$PATH"
HOUDINI_PATH = "C:\Users\PAG\Documents\houdini18.0\Octane_Render;&"
HOUDINI_DSO_ERROR = 2
