Cinema4D version 2020.1-RC1[R2] (ReleaseCandidate)29.02.2020
fLuppster wrote:Installed it and reopened my scene. Suddenly i had a weird rendering bug. The gold material is fully shown, but it gets overlayed by the sofa. Only happens with the new 2020 build.
Did you try without RTX?
zoppo
This looks like this problem here: viewtopic.php?f=85&t=74034&start=10#p378355
Like some kind of clipping error?
C4D 2025 | Win10
mojave
It does indeed look like the same issue. We have solved a couple of similar cases in an internal build yet to be released but just to confirm it is the same it would be great if any of you guys could share a repro scene.
Thank you.
divasoft
+1 i confirm this problem.
mojave
divasoft wrote:+1 i confirm this problem.
Could you export an ORBX that shows the issue and share it with us? Thank you.
divasoft
Problem appear when RTX is on AND accurate Round edges in material is on too. I will send orbx to pm.
LOVEXMEDIA
Hello!
I am having a weird bug happen when in the node editor. Some nodes will randomly disappear upon opening a file and starting the live viewer with that material on an object.
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
LOVEXMEDIA wrote:Hello!
Is it same the case when you drop multi materials to node editor?
pxlntwrk
I had a similar case, when I re-opened a file some previously created nodes disappeared (random color in my case).
I will point out more specifically, if this happens again.
2020.1-RC1 ,c4dR21 latest
pxlntwrk.net
It's about some extra work on node editor to prepare structure for an incoming feature. I will bring a newer build to fix it.
