OctaneRender 2020.1 LightWave Beta build 2020.1.0.2
juanjgon
I've asked to the core devs about the limited region denoising issue because I'm not sure if it could be a problem on the plugin side of if it is a core limitation.
hkleton
Yesterday I installed the latest NVIDIA driver.
No positive results though, still a crash.
But, I did some more testing, and disabled Out Of Core.
Still got a renderfailure, but no more crashes from Lightwave/Octane.
So , like Lewis already said, something is acting up in the Out of Core routines.
Hans
Carlos3D
juanjgon wrote:I've asked to the core devs about the limited region denoising issue because I'm not sure if it could be a problem on the plugin side of if it is a core limitation.
It is a pity.
But what about Octane's native region limit?
hkleton
Any sight of an update?
Were you able to reproduce my problems with the scene I sent you?
Hans
juanjgon
Early next week I'll release a new plugin build including the latest RC1 core, that perhaps could help with your issue. Lewis has found that at least in his system the memory-related CUDA errors only happen when you are rendering with the display GPU. With it disabled, all seems to work fine. I hope that this could help to finally this issue, that to me seems related to some kind of bug in the NVIDIA drivers.
hkleton
Thank for the reply!
That makes me happy!
We'll see whats going to happen, I'll let you know ofcourse.
xevious2501
So here's whats possibly a dumb question.
Why is it that octanes Texture image nodes only offer 3 level selection of UV's to choose from?
Are we limited to only 3? or is their a way around this.
thx :roll:
juanjgon
xevious2501 wrote:So here's whats possibly a dumb question.
This is an Octane core limitation, to save GPU memory it only allows 3 UV maps in each object at the same time.
LichtUndSchatten
Some new information about this Topic?
Like Carlos said, the possibility of beeing able to use denoiser on limited region would be a mileston in workflow optimization.
And the next step would be the combination with animated limited region plugin of odtools for animated objects :)
Return to “Lightwave 3D”
