OctaneRender 2019.1 LightWave Production build 2019.1.5.1
Sorry, but I can't reproduce these problems here. Can you please share your scene and the steps to try to reproduce this problem here?promity wrote:Octane crashes with convert materials command and when closing the IPR window - LW 2020.
Also, can you please double-check that you have the right plugin installed for LW2020 and if you have two plugins loaded at the same time. In the "About" window you can check the installed plugin.
Hi Juanjgon. I use the plugin for LW 2020, i.e. the latest modification of Octane 2019, which I downloaded today. I worked with this scene, which can be downloaded from the link below. I just selected all the objects and used the “Material Conversion” command - the LW 2020 crashes right away.
https://www.facebook.com/groups/lightwi ... 114750806/
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Lightwave 3d
Yep, you are right. It seems that there is a problem with the LW2020 SDK and this feature that I had missed. I'll investigate it ASAP.promity wrote:Hi Juanjgon. I use the plugin for LW 2020, i.e. the latest modification of Octane 2019, which I downloaded today. I worked with this scene, which can be downloaded from the link below. I just selected all the objects and used the “Material Conversion” command - the LW 2020 crashes right away.
