Version 3.08-RC4
dinf
aoktar wrote:What's reason of using standard materials in blend?
Mine would be to be able to use all of so far made materials wich are in my library. So one could plug in and go on, instead of doing them all again if you want to use them with blending. Some of these materials are really complex.
Or is blend mat not comparable to mix material, but slightly easier to use?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
pxlntwrk
aoktar wrote:@pxlntwrk
I'll not remove Mix material system any soon. It will stay as SA having that.
You cannot use other materials with Blend material but ok to use it with mix materials. What's reason of using standard materials in blend?
Btw I cannot reproduce crash, could you send a bugreport?
As mentioned above by DINF, I also already have a lot of standard library materials and i want to know if i can quickly use them with the new blend system .
I understand that the optimal way would be to redo all links with a subMat, but sometimes I think I would not have time. That's why I'm learning about these possibilities.
here is the bugreport
_BugReport.zip
Bug Report + config spec
(146.36 KiB) Downloaded 407 times
pxlntwrk.net
Blend and mix material is similar in depth. Both are built on top mix system in Octane core side, but blend material is offering a better way to hold and edit submaterials.
Currently it's not implemented to connect and convert any other materials. I'll check it for future. Better way is to implement a converter for mixed setups to blend setup. It's more safe way for me atm.
dinf
aoktar wrote:I'll check it for future. Better way is to implement a converter for mixed setups to blend setup. It's more safe way for me atm.
Both thoughts sound very good to me - many thanks in advance!
Ron
dinf wrote:
pxlntwrk wrote:other thing,I do not know if one day I will use so many submaterials but,
when i type 11 or 12 to determine the number of submats c4d crash instanly
I can confirm that. GTX 1080, Dual Xeon, Win 10. I*ll send you a bugreport.
Same for me. Sudden crash after change to 12 slots.
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
niestudio
Same for me on Mac RC4
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
basdumoulin
I am having an issue with motion blur. It seems that as soon as i turn on the Motion Vector pass, the motion blur stops working.
The pass also doesn't look like anything I'd expect. (just 4 colors mapped as squares over the entire scene)
Infochannels switching happens to me as well - though it doesn't bother me much.
3.08- RC4
2x 1070
R19
basdumoulin wrote:I am having an issue with motion blur. It seems that as soon as i turn on the Motion Vector pass, the motion blur stops working.
3.08- RC4
2x 1070
R19
please, have a look at this discussion with example scene about Vector Motion pass:
viewtopic.php?f=30&t=56334&p=288986&hil ... on#p288986
ciao Beppe
pixelbrain
I am having a problem with the Sky Object in 3.08-RC4 (I haven't tested this in previous versions/RCs). The problem is that when I add an Octane Texture Environment and look at the Environment Tag the Texture is assigned as an RgbSpectrum. When I try to change this to a Gradient, the control breaks and I cannot control the Gradient or reassign to RgbSpectrum or any other Texture type. This is not a problem when you first create the Sky Object, only when you deselect/reselect the Sky Object in the Object Manager.
R19.053
Mac OS 10.13.4
example.c4d.zip
(89.06 KiB) Downloaded 326 times
MacPro5,1: 2.4 GHz 12-Core Intel Xeon
MacOS 10.13.6
128 GB DDR3
NVIDIA GeForce GTX 980Ti + NVIDIA GeForce GTX 1080Ti
Cinema 4D R20
Octane v2018.1-RC3
rayrayato
I am also getting a random switch from pathtracing to infochannel kernel. Not sure what key i'm pressing but it's happening a lot on this project. Is there a keyboards shortcut table posted anywhere I can look at?
Win 10 Pro 64 | 2x GeForce GTX Titan X | i7 5960X | 64GB
