OctaneRender® for 3ds max® v3.06.4 - 4.41 [OBSELETE]
paride4331
@darkline
Hi darkline,
Here a clip with my test (3dsMax 2014 Octane plugin render 4.41)
about your image bands and artifacts, share your scene please;
Send me a wetransfer link using private message.
Regards
Paride
01.mp4
(7.95 MiB) Downloaded 3311 times
paride4331
Hi DartFrog,
could you kindly share your issue about ID material?
Regards
Paride
DartFrog
Hi Paride, I have sent it to you.
Thank you!
paride4331
Hi DartFrog,
I tested your material, I made a simple sample for you.
Mesh UV seems to work.
attached .max file
Regards
Paride
02.zip
(347.89 KiB) Downloaded 221 times
paride4331
@darkline
I did not find any issues under 3dsMax 2014 and Octane Render 3dsMax 4.41.
maybe your issue is because "Area to Render", in Max frame buffer, was set to crop instead of view.
Regards
Paride
HHbomb
"Added a general shadow pass, which shows all direct light shadows that calculated on the first bounce"
I can find this in octane viewport render pass rollout "shadow pass", but I can't find it in render element .... Anybody ?
paride4331
Hi HHbomb,
need to add in Render Elements.
Paride
darkline
thanks Paride I will try again and hope it works!
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
darkline
Hi Paride
Setting the area to 'crop' was causing the problem. You may want to report this to developers as I wouldn't expect it to produce those kinds of artifacts because of that.
But thank you - seems fixed now and rendering correctly
