Here is a good collection of IES lights.
http://www.metalumen.com/products/iesall?sub=117
You can also get IES lights and a viewer from GE website
Here is a very good discription of how to use them
http://www.cgarena.com/freestuff/tutori ... ieslights/
A IES light viewer and generator
IES lights - first tests
- mib2berlin
Each file has to safe as single .ies file.
Open one, you see the text, use the File > Save menu from your browser.
Cheers, mib
Cheers, mib
- Attachments
- AR800FT.ies.zip
- First file from Architectural Euro Series
- (1.35 KiB) Downloaded 343 times
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
this is my test
I first adjust scenario of lightning in relux. There i spent some time calculating needed lumens for this test scene.
When i found out what is number of light sources, their location etc i recreate scene in octane, and put some boxes
I used blackbody cos its was intersting to me to adjust Kelvins of lights too
Then i render it octane.
Damn, pathtracing took some time, more that hour on 460 2 gb which is too slow for me
these are pics...
this is so simple scene and cos of time needed its usefull only for final image.
*** I wish that direct lightning can do some kind of radiocity and can pass light trough glass cos its needed for test purpouses and animation too
these are pics...
ArchiCad, Blender, Moi3d
GTX 580 3GB
Win 7, 64 Bit
GTX 580 3GB
Win 7, 64 Bit
- jan kudelasek
- Contact:
andrian wrote:Another quick 20 minutes render, it seems renders cleared much faster using IES lights compared to area lights..
Notice the nice shadows coming from the lights above picture frames..
Hi Andrian,
could you tell me how power (in Watt system) has a emitter in this image.
Thanks a lot.
Jan
W7 / Quad Core Xeon E5405 / 24G / Asus ENGTX 480, 580 / http://www.allcity.cz / https://www.facebook.com/pages/Allcity/ ... e=bookmark
Hi. 20 watts per light with efficiency 0.05.. I might upload the IES used later when I get home..
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
CGsociety gallery
My portfolio
Web site
- jan kudelasek
- Contact:
andrian wrote:Hi. 20 watts per light with efficiency 0.05.. I might upload the IES used later when I get home..
thanks a lot. I have some troubles whit set this new lighting system.Sometimes it produce a lot of noise and fireflyes.
cheers Jan
Sorry for the delay, I was kind of busy. Here is the IES file used.. :
CGsociety gallery
My portfolio
Web site
CGsociety gallery
My portfolio
Web site
Hi
if you need some IES you download a SITECO Light Tools from this adress
http://www.siteco.com/en/service/planning-tools.html
you can find here a whole base of light fixture with IES file
Vista 64 bit|GeForce GTX 260|Duo 3Ghz|8 Gb
The IES emitter material is supposed to be assigned to a sphere instead of a plane or any other object. It won´t lit the scene correctly if not assigned to a sphere.
Chris
Chris
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
