PXL+DIRT grunge/dirt helper [2019/10/10 update]
underworldtr
Huge time saver! Thanks for your great work pxlntwrk...
C4D r18.048 / Octane Render Plug-in 3.06 / Turbulence FD (Build 1425) / X Particles 3.5
Titan X & GTX 1080
Win 7 Ultimate
VVG
pxlntwrk wrote:hi,
new version
update on top of the first post..
viewtopic.php?f=30&t=59827&hilit=pxl#p306211
Cheers
cool!!
Thanks you pxlntwrk
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
drmaddogs2
Absolutely love the last edition, very respectable time in the Plug for adding Mat layers! Twice as fast as any I've used. Here's to hoping some improvements come as to 'Ranges' and more Materials.. I'll happily submit a fee for a completed and commercial charge for the work you have accomplished! Even at this stage of development, lol!
Elvissuperstar007
And you can create such a plugin to 3ds max , Price put, you have a lot of people will buy
pxlntwrk
many thanks for kind words ;)
@drmaddogs2 : At the very base it is only a personal tool. So I do not think of doing maintenance or improvements. If there are changes, the mind will be more towards simplification, which will be more suitable for my everyday use.
@Elvissuperstar007: Oh, it's been a while since I opened this old bear,
However the nodes are there, and someone may be able to try to drive them with a 3ds max script system similar to Xpresso in Cinema 4d. If I am capable, I would be happy to help!
Ciao
pxlntwrk.net
drmaddogs2
pxlntwrk Thanks again, I find your, ' personal tool' is comparable like where Brograph Luminous helps eliminate building from scratch, and substantially has benefits Octane doesn't address. Not 'plugging' "Luminous", just saying you produced a fine effort(might want to give a call to Brograph.. they like these ideas!).
Any other 'personal tools' you might want to share??????? :idea:
pxlntwrk
@drmaddogs2: thanks, I will think about it ;)
Here is a small sequence, showing another example of use
more info on this xpresso setup : here and there
ciao !
pxlntwrk.net
raul_pier
Great I just order it.
update... 8/8
Seems like if Sticker is not working under Ver R16.050, I am not getting the option
Sticker.1
....bitmap RGBa
Like in the tutorial, where I can pick a sticker.
update.. 8/10
It worked perfectly under ver 17,
Amazing tool, easy to use, thumbs up. A+++++++++++++++++++++++++++++
Best regards.
RP
i7 6 Core Processor | ASUS ROG GeForce GTX 1080 Ti 11gb x 2
Adept
Anyone know if there is a way to use this with multiple materials on one object? I have a single mesh that has 6 different materials applied to it, but in the pxl settings you can only select one "clean material." Any ways to do this? The materials are uv mapped onto the object as well.
EDIT:
I realized I could add the pxl mix mat onto a selection tag for the part I wanted it on.
