Modo Plug use only 85% of GPU power
I exported the scene in Orbex, just lunched in Stand Alone and this is the results.
Standalone is using the same GPU percent as the Modo plugin. So the issue is as per the top of this thread.
in order to get 100%, you need a complex scene, since with a simple scene everything is running too quickly to max out the GPU. See "overhaul of the integration kernels" in viewtopic.php?f=24&t=51679.
balaccog
Hi Paul I used an interior scene, so quite complex.
As the screens that I posted early, with the version 2 of the octane the load was 99.
I repeat, maybe I miss something, but I would like to understand why this is happening.
Urania:
i7 - 3930k
32 Gb
1 x GTX 980 ti
2 x GTX 570 HD 2560Mb Vram
Just because it is an interior scene does not mean it is complex. Many many light sources are there? How many triangles?
Return to “Foundry Modo”
