Image Sequence F10/LWSN Crashes with Material Update
LightwaveGuru
juanjgon wrote:Sorry, I've rendered several frames here using LWSN without problems so far. If you can reproduce this problem rendering with F10, can you please enable the log file and send it to me to know where it is crashing?
Anyway I will continue testing the scene here to see if I can reproduce the problem.
There is no Problem. It works here for example 100% save with 3.00.10.0 i make a short video for 3dreamstudio...and drop here later the link...
snip lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
3dreamstudios
snip lwguru
We'll there may not be a problem for you...but I certainly could record a video of there being an issue here. Now the fact that it can't be replicated on Juanjgon's computer with all the same assets bogles my mind...but there again we all have different configurations and it could be related to something there. Not sure.
All I know is I can replicate it....It has cause many headaches for the last 5 days of rendering, trying to get work out.
I appreciate you letting me know "you" do not have any issues on your setup. Juanjo has made himself available for help and I appreciate that as well.
LightwaveGuru
snip lwguru
there is no problem with that function in alpha 3.00.10.0...i think its your scene set up...can you send me a link to that magic scene ;)....all my test here work very well :)
snip lwguru
3dreamstudios
I'm currently using 3.00.6 and have not tried .10 yet. If I can replicate on .10 once renders are complete (probably tomorrow) I would entertain sending over the magic scene :) to see if it can be replicated. Thanks.
LightwaveGuru
"We'll there may not be a problem for you."
here a link to the video...that mean your scene set up is wrong or the image sequence have illegal ASCI Code?
https://youtu.be/e8rc8bNGvIQ
snip lwguru
LightwaveGuru
3dreamstudios wrote:I'm currently using 3.00.6 and have not tried .10 yet. If I can replicate on .10 once renders are complete (probably tomorrow) I would entertain sending over the magic scene :) to see if it can be replicated. Thanks.
...its NOT a problem from Octane...it works in all versions perfect...
snip lwguru
Return to “Lightwave 3D”
