not in all scenes but sometimes occurs such a problem
2016 max
I posted part of the scene - it occurs in the same way oshibka I have one solution a new scene and merge the old stage in new
OctaneRender® for 3ds max® v2.23.2 - 2.8 [OBSOLETE]
- Attachments
- Untitled.zip
- (673.13 KiB) Downloaded 297 times
Moving to 2.8 from 2.1, when I have an target Octane Camera focus set on "Target" I get nothing but grainy white renders. If I change the focus to manual or auto focus, it works fine.
Win 8.1 | 4.1ghz 5960x | Cinema 4D R20 / 3ds Max 2018 | 2 x Titan Z + 980
Win 10 | 3.0ghz 2697 v3 | Cinema 4D R20 / 3ds Max 2018 | 4 x 980ti hydros
4 x Win 7 | 4.0ghz 5930k | 4 x Titan Black or 4 x 980ti
SOS !!! SOS !!! SOS !!! SOS !!!! the positioning error of the camera to viewport
camera mapping is in big a...s
test 3dmax 15 - 16
test 1.9 - 2.8 - no work correctly
the project starts on Friday !!!!! JIM !!!! you can fix this critical error
test 3dmax 15 - 16
Octane DEMO
- error message on max 2014 and 2015, win 8.1. ..still.. - everywhere else works ok, is there an entry in a .ini file or something..
3dmax, zbrush, UE
//Behance profile //BOONAR
- ricardobjerke
- Contact:
I can't get the plugin to work.
It simply won't detect my GPU inside Octane's 3ds max plugin. The weirdest thing is that it works just fine on the standalone version.
Machine's configuration:
Geforce GTX 970
Nvidia driver 355.82
3dsmax 2015/16
Octane Plugin v.2.23.2-2.8
Octane Standalone v.2.24.1
Extra info:
The scene was built inside of max. I only opened it in Octane in order to check if the problem was Octane standalone or plugin related
The scene renders fine in other machines with the same configs (standalone and plugin versions)
It is NOT a scene related problem. The plugin doesnt work at all
I've just formated and reinstalled the OS and programs in the hope that something could be wrong with my OS, but it didn't help at all
I also disabled the onboard GPU in the BIOS to eliminate any sort of conflict between the onboard GPU and the GTX 970
ANYONE?!
Geforce GTX 970
3dsmax 2015/16
Extra info:
ANYONE?!
I also use the CG-Source HDR images. And it is a natural behaviour that you will get black reflections from the ground, if the ground is black.
They are intended to use with a proper floor, usually your terrain and then add some background images (with alpha) like trees or so to get more spiced up window reflections.
PURE3D Visualisierungen
mbetke, unfortunately probably not everyone knows about it.
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
- Elvissuperstar007
- Contact:
then add the necessary support for this featurembetke wrote:I also use the CG-Source HDR images. And it is a natural behaviour that you will get black reflections from the ground, if the ground is black.![]()
Elvissuperstar007, this thread is not for requests.
