Displacement - another issue
bleepurchin
bleepurchin wrote:Ok so I've remodeled it and here it is. I've not made the mesh as dense as yrs as I figured I could use the object tag to smooth the mesh for me.
Am I right in thinking that I can unwrap this mesh now? I'd like a word or advise on that before I take it much further please.
Dis_Iss_02.rar
Many thanks again!
Luke.
Soooo it wasnt good enough and I ended up making a mesh similar to yours, unwrapping the UVs/ projecting them...and yep....the displacement was ... better!
but not perfect ... 85-90% better.... I am seriously hoping hard right now that in V3 the displacement is a lot more robust!! :D
Cheers!
Luke.
Software: Cinema 4D r16, Octane v2.24.2 R1
Hardware: Intel Core i7-5930K CPU 3.50GHz, RAM 32 GB, 3x GeForce GTX 980
djart
@bleepchurchin,
you could try this methode for displacement...
see attached file.
cheers,
djart
3djart_octane_c4d_displacement_V2.rar
(1.23 MiB) Downloaded 96 times
bleepurchin
Good call DJart,
I just don't want to start subdividing up my meshes... I have hundreds and I'm starting to realise most will be fine with a bump/normal map...
Cheers though.
L.
hi bleepurchin,
I have modified the uv of your second model without changing the polygons subdivision:
Dis_Iss_02-beppe.c4d.zip
(177.35 KiB) Downloaded 106 times
As Yambo said, the uv unwrapping is crucial for good displacement ;)
bleepurchin
Yeah thats how I unwrapped it in the end... you cant seem to get away from the seems being at risk of weird results though...
