error with the IPR window preview!
juanjgon
chris_solo wrote:I tested, so no flickering in the IPR window ;)
but information IPR are not displayed permanently...
I also find that the render is made per whereas before it was done gradually in the window...
I put a little video for you to see what I mean.
error.mov
I didn't have this kind of problems with older versions.
Chris
Thanks for reporting. It is really a weird behavior. I need to make more tests.
juanjgon
marchermitte wrote:Ok, I did deleted all of the Kernel nodes and rebuilt It but still, same problem... only the samples go up to 35 in direct lighting / ambiant occlusion mode and up to 13 for diffuse... so It seems It's not so much the samples but the time that counts (2 seconds loop). I will send a link to the scene, It's pretty heavy do I'll host It somewhere and pm you the link.
Thank you for your time!
Yes please. I think that I have seen this behavior before some time ago, from other user reporting, but I can't remember what was the problem :(
juanjgon
I have a new build to test the flickering problems in the IPR. Please test it to know how it works.
The 2015 plugin has been updated to the 2015.2 LW SDK, but it should work also with 2015.1
https://www.dropbox.com/s/7uvhhs60v0iiu ... l.rar?dl=0
chris_solo
I will test this evening at my home :) I will return to you after this test
Thank you for you work.
Chris
chris_solo
hi juanjgo,
this seems OK, :D nice work!
only thing, is it normal that the second doesn't scroll in real time after a while, but per round... I feel.
thank you
Chris
juanjgon
chris_solo wrote:hi juanjgo,
I don't understand you issue ... what scroll, the mouse wheel?
chris_solo
sorry I don't speak/write English well, I meant that the time (second) takes place in real time but after a while it is made by several second in the display.
...so I think that it is normal by analyzing a little more. :)
time.mov
(807.47 KiB) Downloaded 2798 times
to show you that everything is good :
OK (1).mov
(3.77 MiB) Downloaded 2770 times
Chris
juanjgon
chris_solo wrote:sorry I don't speak/write English well, I meant that the time (second) takes place in real time but after a while it is made by several second in the display.
Yes, it is normal, the time is only updated after each new image from Octane, when the plugin updates also the sampling information and so on.
marchermitte
I sent you the link in a PM.
Again, thank you very much!
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
juanjgon
marchermitte wrote:I sent you the link in a PM.
Thanks, after see your scene I just remember what is the problem: you have the "Studio LIVE" enabled. In this mode the Layout is sending continuous refresh commands, and the IPR becomes crazy ;)
Disable this option, it is not compatible with Octane.
Return to “Lightwave 3D”
