smooth and Rounded Edges problem
denver2
face_off wrote:
Hi -set the subdivision level of the mesh to 1 - DOES NOT SOLVE THE PROBLEM!
Below is Roxy, at subd 1 (in the Octane settings), with sun size 2, and ray epsilon 0.00001. I don't see any artifacts.
Also - as Zay rightly says, you can rescale the scene in the Configuration settings to get around this.
here is the link YOUR screenshot in increasing
http://joxi.ru/3PIjVP3JTJAHTEQNthA
there are visible artifacts
denver2
The words of Zay only confirm what Octane all a year sells unfinished product for the price finished. AND DOES NOT WARN ABOUT PROBLEMS!
Hi - I can see the artifact in the Poser mesh too. I suspect there is an issue with the mesh at that point cause is causing rendering problems.
Daylight rendering is effectively a very small point light - so any mesh issues are going to be problems. "texture environment" lighting on the other hand is far more forgiving of these mesh issues because the light is coming from all directions.
denver2
face_off wrote:Hi - I can see the artifact in the Poser mesh too. I suspect there is an issue with the mesh at that point cause is causing rendering problems.
Thank you!
However, in other applications, this problem is absent.
none of the developers had warned me that there is a problem!
when I was paying for the program
If you set the sun size to 10, the problem also goes away. So there are many workarounds. And if you give Otoy a chance - they will look into the problem.
denver2
Thank you! I'll try
Return to “Poser”
