thanks for your fast reply!
If you see this line, then at least some version of the plug-in is loading. If you select this line, then hit the properties button, it will show the Plug-in Properties page in which you can see which version has loaded. It should be 1.022r01.02a.
...yes, this is the version I see when I click on properties.
In the toolbar in the zip file, there should be two buttons. One starts the renderer, a left click will let you choose where and what to call the exported file, right click will choose for you. The other button will let you set the options for export, including which version of Octane you want to use. Left click on this will start the OctaneOptions, which lets you set the Octane Path, the number of samples, start rendering on open, and which cards to use.
This is the point: I haven't no button of the Octane plug-in when I open Rhino v4. I have searched it inside a lot of way, but with no result...All that you write to me is very comprehensible but I haven't no way for to test what you are writing...
I hope that with Rhino v4 and Octane plug-in I can export the .obj file with all its layers (and therefore all its objects for layers).
Garcia
