Stops while rendering
coilbook
Rico_uk wrote:http://render.otoy.com/forum/viewtopic. ... 3&start=20
the bottom of this page / thread seems to be a similar issue in Standalone. I'll try out the subsampling setting, but I've never changed that so it'd be strange.
It seems like there's a few people having this problem now in latest versions.
thanks for link
last night i tried to render and it did 200 frames, then relaunched it it did about 100, etc after restarting render 7 times it does 2 frames and freezes. And seems like more objects with motion blur i have and if i use autofocus worse it gets
Otoy please fix it . cannnot render animations at all
coilbook
2.04 still freezes during animation mostly 700 error lol
DayDreamer
CUDA error 700 on device 0: Error code unknown.
-> failed to deallocate device memory
-> could not get memory info
This is eating my brain out. Is it a so called memory leak?
p.s.
Found one silly reason for this - i belive it can be replicated by having two (nearly)identical meshes, same size, same placement, intersect. (I had two different car wheels on the same place) And have them chromed. :D
Maybe rays bounced too much and crashed the whole render.
CPU: 5930K i7, GPU: 2x iChill Nvidia 780Ti, 980, RAM:32GB, Win 7, SSD.
mastergoo
In my case I've found out that animation freezes because of not enough cooling. I tested several times. Same sceene on high coolers' RPM renders fine, on automatic cooling setting it freeses. After i have redone cable managment in chasis so that airflow became much more accurate it became okey in automatic cooling settings.
ps: this issue is actual if you have multiple cards of course, one card should be ok in any way.
DayDreamer
mastergoo wrote:In my case I've found out that animation freezes because of not enough cooling. I tested several times. Same sceene on high coolers' RPM renders fine, on automatic cooling setting it freeses. After i have redone cable managment in chasis so that airflow became much more accurate it became okey in automatic cooling settings.
How did you know? :D It's so confusing, how would you do a night render if Octane just blows after half an hour :(
Return to “Autodesk 3Ds Max”
