Beta 2.2 RC1: Blender 2.55 Export Script testing thread
SnoWWolf
Hi Nautilus! Are you using Beta 2.2 or new beta 2.3 v5?
E6600 | Win7 pro x64 | GTX 460 2gb | 4 GB | Blender 2.54 | python 3.1.2
the_nautilus
Tried it with both versions at home, but Blender seems to get stuck before even initializing Octane.
bepea
the_nautilus wrote:Hmmm, yea at work everything is fine for me, but at home I have a similar problem where Blender just hangs, even with export sun feature disabled. I looked at the console screen and it's giving me an "Exception: Octane plug-in: Cannot find scenes directory" despite the fact that I defined the binary, project path and project name (with no spaces just to be sure). The only real difference is at work it's XP 64 and home it's Win 7 64, but I don't see how that would make any difference.
Double check you paths because when I use the file selection dialog box in Blender I get a path like this: "//..\..\..\Program Files\Refractive Software\Octane Render 1.022b x64\octane.exe" and I have to correct it manually.
Intel i3 530 3.0 ghz | 4 gb ddr3 ram(1600) | NVIDIA GeForce GTS 250 1gb | Windows 7 x64 / Ubuntu Linux 10.4.1 x64
SnoWWolf
I checked the paths - ok
blender shows this in console, octane isn't starting, task manager shows no process activity
BTW Blender 2.49 works fine, exports and opens octane without issues.
ycarry
In File browser, when path choose, simply select file path in top field, copy and past in Project path field: it want real path, no relative.
And if Export sun is checked... sun need to exist in scene.
Works well for me, enricocerica, thanks! :)
No tested in animations...
bepea
snowwolf: You need to change the "project path" from relative to absolute path, eg.: "c:\octane_projects"
SnoWWolf
THX! it works!
franbec
Thanks enrico. Great job, working fine in Blender 2.54 latest releases win 7 64,and octane pre 2.35 win 64.
Win 7 x64 | Gainward Gtx560ti 2gb | CoreI5 2500k 16GB |Blender 2.49|Sketchup|
steveps3
I am struggling to get images to export. If I check the "Copy image files" button, Octane crashes every time. At the moment I am having to change the diffuse colour to image every time I render.
(OS) Windows 7(64)
enricocerica
steveps3 wrote:I am struggling to get images to export. If I check the "Copy image files" button, Octane crashes every time. At the moment I am having to change the diffuse colour to image every time I render.
Are you using relative paths for the images ? If so you may convert them to absolute path, will check later on if I can manage relative paths in the script but for now it seems to be a problem.
http://www.myline.be
Return to “Blender”
