OctaneRender® for 3ds max® v1.53a
User avatar (Default)
merid888
thank you karba, i'll test
regards
RobSteady
Please please please Color Correction Node support in the next relase!!!
Also for V-Ray material conversion....
mbetke
Is this a BUG?:
1. Do a plane with matte material.
2. Place a cube with a generic material.
3. Plance another cube and set it to "invisible to camera" in object properties.
4. Use a HDRI for lighting the scene.
5. Render.
Now both cubes cast a shadow on the matte plane. But only one cube should do.
PURE3D Visualisierungen
Karba
mbetke wrote:Is this a BUG?:
5. Render.
invisible to camera doesn't mean invisible to everything else. It is still visible for shadows, reflections, refractions and GI.
Karba
RobSteady wrote:Please please please Color Correction Node support in the next relase!!!
Both are there for ages.
boris
I guess he means hue correction.
And that's what I like to have, too :)
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
boris
Hey Karba, first:
Nice release.
Anyway I have another question.
A couple of days ago I asked the Itoo developers about the plans to make railclone pro natively compatible with octane render (that means without converting the railclone parts to movable proxies and bloating the scene in some cases).
His answer:
Unfortunately there are not plans to support Octane natively in RailClone. We need the collaboration of Otoy, but until now they don't seem interested.
Can you confirm this (explanation)?
cheers
boris
RobSteady
Karba wrote:Both are there for ages.
Hue & Saturation control please!
Maybe support for the internal 3ds Max Color Correction node.
This one
Also support for conversion:
I've got a ton of V-Ray scenes and models with color correction maps and they are not getting translated.
For me it's an essential and very basic feature.
It's VERY time consuming to go back and forth in Photoshop and Max:
Render, open texture in Photoshop, GUESS hue, save under different name, reload map in Max, render. And then the same thing over again because it will not be right the first time.
So please :?
suvakas
Awesome! Thanks a lot for camera blur duration !
Suv
pixelsolution
Karba wrote:
pixelsolution wrote:pixelsolution wrote:Hi Karba
With this new version i am facing below problems..
1. i m not able to get render view-port done (it is showing black..)
2. when i was using previous version 1.5a, i that on view poet 3 buildings were open and when i turn 4th building whole building turns to black and at some places there colors also changes.
The same project is running very stable and smoothly with 1.20. and it is rendering in 3 min with full HD quality 1200 samples
pixelsolution
core i 7 4700k / 32 gb ddr 3 1600 ram / 2x titan.
Karba:~What is your texture statistic?
60/144.... (this communication was done in 1.53 link..
using 1.53a same issue...
After waiting for above an hour we did not found any progress. so we took this snap shot.. we have even rebooted the system but same issue..
Please help...
pixelsolution
May I have your scene?
[email protected]
Hi karba.
It is difficult to send the file as its size is 2.3 gb
Return to “Autodesk 3Ds Max”
