OctaneRender for AutoCAD Beta 1.20 trial comment
If you post the AutoCAD scene with the PolyFaceMesh in it (zip format) in this thread I will take a closer look at the problem.
kwaikeong1402
hi Paul,
Pls refer to the attachment file.
thanks :D
DRF-1997 Octane Render.zip
(13.25 MiB) Downloaded 434 times
kwaikeong1402
hi Paul,
my autocad version is 2014. May I know when your will release version which is support autocad 2015?
Thanks!
I have done some preliminary work on this, and it is not as simple as recompiling the plugin for 2015. So it will take some work. I will look into it in more detail over the next week.
Update on AutoCAD 2015 - it looks like there are issues with the plugin autoloader in AutoCAD 2015, which is preventing the Octane plugin for automatically loading - and Autodesk have flagged this as a bug, so I expect to see a fix for this in the first service of AutoCAD 2015. Until then the plugin can be manually run via the AutoCAD command line. If anyone upgrades to 2015, pls let me know and I will post a test build for you to try.
kwaikeong1402
Hi Paul,
Im using autocad 2015 now.
Regarding the polyfacemesh problem, have you try to solve it? Any solution?
Thank you!!
Could I direct you to this thread pls - http://render.otoy.com/forum/viewtopic.php?f=72&t=38976 - that way everything is in one place :-)
I have posted a release for AutoCAD2015. No news on the polyfacemesh yet.
kwaikeong1402
I have some questions:
1)May I know how to find out the favourites after I saved it? I can't do the backup.How to delete the unwanted favourites?
2)After photo done, how to save it in png with alpha channel?
Thank you!! :)
Favorites are stored in the C:\Users\[username]\AppData\Local\OctaneRender for AutoCAD\Favourites folder, so you can back them up or delete them there. See http://render.otoy.com/manuals/AutoCAD/?page_id=501 for details.
You need to render with Alpha Channel enabled in the Kernel Settings (in the Setup tab tree). See http://render.otoy.com/manuals/AutoCAD/?page_id=46 for details.
kwaikeong1402
thanks Paul :D
