Texture blend in 1.2x?
Rikk The Gaijin
Thank you!! :lol:
Rikk The Gaijin
Roeland, can you show me how to modify your script in order to have a material blend, instead of a texture blend?
I simply want to use a Mix Material node and blend the two materials from start to end of an animation.
roeland
There is no change required. Select the node attached to the mix input of a material node instead of a texture node.
Roeland
Rikk The Gaijin
roeland wrote:There is no change required. Select the node attached to the mix input of a material node instead of a texture node.
Roeland
Splendid! It works great, and in this way I can also blend normal maps! :lol:
