Texture blend in 1.2x?
- Rikk The Gaijin
Roeland, can you show me how to modify your script in order to have a material blend, instead of a texture blend?
I simply want to use a Mix Material node and blend the two materials from start to end of an animation.
- Rikk The Gaijin
Splendid! It works great, and in this way I can also blend normal maps!roeland wrote:There is no change required. Select the node attached to the mix input of a material node instead of a texture node.
Roeland
