OctaneRender® for Poser (Windows) - build 1.20a [OBSOLETE]
Tiny update with the following....
1.20a3
- Versioning changes to reflect the plugin is now out of beta (ie. new heading bitmap)
- Fixed rounding error when converting from RGB to Linear color space
Download from the link at the top of this thread.
Airfoil
The download link goes to a page that states "The requested file does not exist".
Airfoil
Sorry - fixed now.
Andygraph3D
Windows 7 64 bit
poser 9
quadro 2000
I have make update octane render and plugin and now i have found this error in startup:
An errror occurred importing addon OctaneRender for Poser :
ERROR: function 'PoserOctaneSharedStart' not found
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 231, in loadData
TypeError: expected string or Unicode object, NoneType found
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 148, in objectSelected
AttributeError: 'NoneType' object has no attribute 'DEBUG'
It looks like maybe there is a date/time issue and the installer hasn't copied over the new files. Could I trouble you to install the plugin via the Windows control panel, and reinstall and see if that resolves the issue.
Andygraph3D
But i need uninstall the octane poser plugin ?
if yes, how ?
Then need i install again via the Windows control panel, how ?
My apologies for the typo - that should have read.... "Could I trouble you to uninstall the plugin via the Windows control panel, and reinstall by running the latest installer and see if that resolves the issue."
Andygraph3D
maybe i have understand the problem .. i have download the plugin for poser 64bit
but i need plugin 1.20 for poser 9 to 32bit
Where can i download it ?
The one installer does both 32 and 64 bit. It auto-detects which OS you have.
Andygraph3D
this is the problem to me install only 64bit
i have windows 64bit
but i use poser 9 32bit (because only poser 9 pro (or 2012 pro) is 64 bit)
Return to “Poser”
