OctaneRender® for 3ds max® v1.12[Test]
Karba
bicket wrote:Hi karba
I have big problems since I try 1.12
For all the scene i build before, I have a popup windows "unkonw system exception" when the scene opens and then the file is corrupted and can't be reopened.
It's very annoying cause i have to rebuild all the scenes from scratch :( :( :(
The biggest problem is that if i come back to version 1.11c, the errors occurs too.
I work on 3dsmax 2012 64b french and english.
Does it start happen right after 1.12 get installed?
Does anyone else has this problem?
MaTtY631990
Great version, love the ability you can change the sun and sky colors. Only problem, is their an option to reset this to default state.
Thanks.
oguzbir
gabrielefx wrote:
oguzbir wrote:
gabrielefx wrote:thank you!
does 1.12 support 224 textures? Titan textures number?
gabriele,
I havent read or know that titan had larger texture limit.
In 1.12 Titan shows support a total of 232 textures so as gtx680's and other keplers. (144rgba+10rgb64+68grey+10grey16)
here I read 224. The GTX 680 doesn't support so many textures.
http://www.bit-tech.net/hardware/2013/0 ... rst-look/1
I'm guessing the texture limit is mainly because of the cuda version. But Titan is capable of using it.
Still guessing that the software has to be adjusted to that..
My Portfolio
abstrax
gabriele,
The texture units they mention in the article are hardware units, part of each streaming multiprocessor (SM). The number of texture units is not the reason for limitations in texture counts, but the way how textures are defined and used in CUDA. Depending on the compute model a different (hard-coded) number of texture references can be used: All GPUs with compute model < 3.0 (Tesla, Fermi) support up to 128 texture references. All GPUs with compute model >= 3.0 support 256 texture references.
We use some texture references for some other stuff, but the rest for image textures in materials. Hence the limited texture counts, i.e. 104 image textures (64+32+4+4) for pre-Kepler GPUs and 232 (144+68+10+10) for Kepler GPUs (including the GTX 680).
Vanya
With an open viewport, it is impossible to change the model, max immediately gives the crash.
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
bicket
I think but not 100% sure about that :
Every scene created with octane 1.11c that i try to open after installing 1.12 generate an "unknown system exception" and can't be saved => file corrupted.
It's also the case of scene that don't use octane : i build a scene for vray as octane 1.11c was installed and can't open it now.
Even if I try to reverse to 1.11c (copy / paste old files in 3dsmax root folder) the problem is the same ...
I can't understand what appends but at this stage octane is definitly not for production and i have to spend one day to rebuild scenes from scratch (reimport geometries into a brand new scene and recreate lighting and render parameters) :evil:
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
gabrielefx
hard disk failure?
disk full?
bicket
gabrielefx wrote:
hard disk failure?
disk full?
Nope, every thing else is ok.
Windows disk error check is ok.
PortFolio
rattle-snake
For me it works great !
There are no problems in my scene.
Tanks a lot for your quick work Karba :D
bicket
I just found the cause of my problem : PhysX
I just re-install the plugins and every thing is ok now :D
But I can't uninstall PhysX for 3dsMax because scenes created while physx was in makes 3DS crashs without :cry:
Karba, sorry :oops: octane is ok. Good work as usual
PortFolio
Return to “Autodesk 3Ds Max”
