Batch render from command line crash
sampakinpa
I found a temporary work around to the crash problem by dividing the render to three sequences: 1-20, 21-40, 41-60 in the batch file. In that way its probably refreshes the memory on each sequence.
But this is not a permanent solution and it must be fixed for us to implement octane to our in-house pipeline.
I added one of the animation mb files that I used for testing:
Ring_223315_ang01.zip
(6.92 MiB) Downloaded 233 times
It we'll be very helpful and appreciated that you and the engine team could use it to help us solve this problem.
Ethan
2x Xeon E5-2620, 32 GB RAM, 4X GTX1080ti, Windows 10, Octane 3 for Maya 2018, Radeon HD6450 for disply BRIO Animation ltd
sampakinpa wrote:I found a temporary work around to the crash problem by dividing the render to three sequences: 1-20, 21-40, 41-60 in the batch file. In that way its probably refreshes the memory on each sequence.
Ethan
Thank you!
Will try to reproduce it with your scene.
sampakinpa
A note about the work around:
As I increase the samples (pt) I need to render in smaller chunks because it crashes more frequently.
Return to “Autodesk Maya”
