OctaneRender® for 3ds max® v1.11[Test]
cfrank78
Tested.........everything works :-)
Maaaahahahahahaha!
Thanks for this great release Octane Team and especially Karba!
PS: In the 1.10 thread i asked for a free camera! Will you soon make it possible? This would be so fantastic! Please maybe you can give a showrt answer!
Regards Chris!
HHbomb
It seems that matte don't work as expected just with sun. We need to add an extra octane light... ?
suvakas
Animation rendering not working correctly.
Sometimes it works, but offten it doesn't render a frame until Max sample rate is reached, but finishes early.
That causes flickering cause some frames get rendered with very low samples per pixel.
At the moment it's not usable for animation work.
Seems like more bugs appear with every new feature that gets added. 1.03 is the latest usable version at the moment.
Suv
cfrank78
Suv
Can confirm that! Frames are not "stabe"! One is darker - next one is brighter, again next one darker and so on! Flickering! Especially if you use Post processing! No matter if you use sunlight or an hdri!
cfrank78
Also the Material Editor previews the Materials wrong!
Kind regards Chris!
cfrank78
Realtime Animation is also not possible anymore! when i click play nothing happens, when stopping the animation the render viewport starts again!
Chris!
cfrank78
Material preview and Realtime Animation suddenly works again after a few restarts! I am trying to reproduce the problem!
Karba
suvakas wrote:Animation rendering not working correctly.
Suv
Could you send me some neighboring frames?
Karba
cfrank78 wrote:Realtime Animation is also not possible anymore! when i click play nothing happens, when stopping the animation the render viewport starts again!
Chris!
What do you mean? Animation of material properties?
Karba
Suv
Ok, I can reproduce this issue.
Will fix it soon.
Return to “Autodesk 3Ds Max”
