Volumetric Generators!
profbetis
Nice! it looks good! How did you manage to have the surface of the shape not show up and just get the inside?
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
FractalBuddha
Thank you :)
I placed the camera the closest possible of the surface and adjusted the offset to be in front of a hole.
I wish I could set myself the coordinates of the volumetric texture.
Imagine reality
2 x GTX 560 | i7 | windows 7
profbetis
You can actually, you can put a transform node on the generator is think, but then you can only do one type of transform : Scale, rotations, or translation. but it does work!
coilbook
profbetis wrote:Here's another test
On this one, I used a custom model of a little clay cube I made a while ago... nothing special, just needed something with a surface beneath it and a different shape.
Anyway I had to turn on the caustic blur to get the light to come through and see how the shadows were rendered. I think the shadows are also only cast by what's drawn.
This shape also lets you see better the weird surface vs. volume SSS which I think needs to be addressed. Why isn't the volume being lit up like the surface? I wonder if it's because the density is far less inside the volume than it is at the surface? or maybe it's that it's being calculated incorrectly?
this is so cool I wonder if anyone has texture for 3ds max plugin thanks
profbetis
Unfortunately a past update removed this functionality in favor of properly intersecting specular materials. Perhaps in the future they'll try to bring this back. :(
coilbook
profbetis wrote:Unfortunately a past update removed this functionality in favor of properly intersecting specular materials. Perhaps in the future they'll try to bring this back. :(
Thank you
acc24ex
fugg this - I was really pumped to try out this right now, tried on 1.18 kernel not working - damn it - otoyctane give us moar cool things to play with, pls
Dakati
I cant seem to get it to work for me, any ideas? I downloaded your example too. All I get is a white sphere
Chris
It does not work anymore ;)
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
jevaone
This is amazing. Is it possible to achieve the same thing with the C4D version of Octane? Or is this only in the Standalone.
thanks!
