This is the first version I have used that did not ask for the license key.
Changing resolutions still crashes Octane now and again, at least under Ubuntu64.
I will try this evening, is possible out of memory???LetoAtrell wrote:Still crashes on resolution change on MacOS X 10.6.3 ... when I select 2048 x 1024 the image turns into black! When I select 4096 x 2048 it crashes
Maybe ... please test it with your setup ... I also have 512MBjohn_petrucci wrote:I will try this evening, is possible out of memory???LetoAtrell wrote:Still crashes on resolution change on MacOS X 10.6.3 ... when I select 2048 x 1024 the image turns into black! When I select 4096 x 2048 it crashes
Hi,LetoAtrell wrote:Maybe ... please test it with your setup ... I also have 512MBjohn_petrucci wrote:I will try this evening, is possible out of memory???LetoAtrell wrote:Still crashes on resolution change on MacOS X 10.6.3 ... when I select 2048 x 1024 the image turns into black! When I select 4096 x 2048 it crashes
