or simply try to get octane to render offline images with the desired resolution ( like vray or other renderers)
i dont know if this is possible with octane.
Enquiring about buying.
Portfolio: http://www.tres31.com/site/
http://www.flickr.com/photos/tres31/
sr2 mobo / dual Xeon E5620 3.2Ghz / geforce gtx 480 + geforce 580 3gb msi twin frozr III / 20gb RAM
Since obj won't use instances, what would it be? collada? In my case at least obj will be of no use then, cause I don't have a single scene that doesn't use instances.
RIB and collada.kubo wrote:Since obj won't use instances, what would it be? collada? In my case at least obj will be of no use then, cause I don't have a single scene that doesn't use instances.
Radiance
What about this:
When will the sun do through the windows? Because right now, only the sky reaches the interior but the sun does leave shadows on the exterior walls, but once it reaches the window it's like the sunlight can't do through the specular material.
sunlight through architectural glass and alpha is on the list for the 2.3 release, with MLT.vimaxus wrote:What about this:
we're finishing 2.2 now, then we begin on it, so it won't be long.
Radiance
