Yes I will.aoktar wrote:Momade,
can you move this to request topic? Better for me to track it. I'll check when sometime ready.
Version 3.00 - R1.1 (25.05.2016)
Hey aoktar.
Not that image sequences in C4D are easy by nature. but I really can not make this work in V3. not in an octane material and also not in an c4d material. can you make this work?
Don't know what you do but it's easy too in octane. Just point sequences and set start/end. We just use own sequence detection in plugin.momade wrote:Hey aoktar.
A: works fine. 201 frames of image sequence and playing them from frame 0 to 200. perfect.aoktar wrote:Don't know what you do but it's easy too in octane. Just point sequences and set start/end. We just use own sequence detection in plugin.momade wrote:Hey aoktar.
B: does not work. same sequence and playing it from frame 600 to 800...
All that happens here is a image switch from first to last image from frame 600 to 601...
Confirming the same issue here.momade wrote:A: works fine. 201 frames of image sequence and playing them from frame 0 to 200. perfect.aoktar wrote:Don't know what you do but it's easy too in octane. Just point sequences and set start/end. We just use own sequence detection in plugin.momade wrote:Hey aoktar.
I'll check it for next release. I'm still on this stacking feature and requires lot of work. I can't make any release before making it workable.valters wrote: Confirming the same issue here.
Thanks aoktaraoktar wrote:I'll check it for next release. I'm still on this stacking feature and requires lot of work. I can't make any release before making it workable.valters wrote: Confirming the same issue here.
Can you make a settings with this sample scene? It's working as i can see here.momade wrote:Thanks aoktaraoktar wrote:I'll check it for next release. I'm still on this stacking feature and requires lot of work. I can't make any release before making it workable.valters wrote: Confirming the same issue here.
- Attachments
- cnt.rar
- (476.18 KiB) Downloaded 289 times
Hey aoktar.
I changed the settings to produce the same masfunktion for both spheres.
please have a look. the counting texture should start running on frame 80.
zip is attached.
zip is attached.
- Attachments
- cnt_MO.zip
- (438.19 KiB) Downloaded 278 times
Beautiful test scene Ahmetaoktar wrote: Can you make a settings with this sample scene? It's working as i can see here.
The issue is not with Movie Start Frame > Movie End Frame that controls Sequence it self but issue is with Range Start > Range End that controls when to start the playback and what to do with it
thanks
