Version 3.00 - R1.1 (25.05.2016)
momade
aoktar wrote:Momade,
can you move this to request topic? Better for me to track it. I'll check when sometime ready.
Yes I will.
momade
Hey aoktar.
Not that image sequences in C4D are easy by nature. but I really can not make this work in V3. not in an octane material and also not in an c4d material. can you make this work?
momade wrote:Hey aoktar.
Don't know what you do but it's easy too in octane. Just point sequences and set start/end. We just use own sequence detection in plugin.
momade
A: works fine. 201 frames of image sequence and playing them from frame 0 to 200. perfect.
B: does not work. same sequence and playing it from frame 600 to 800...
All that happens here is a image switch from first to last image from frame 600 to 601...
valters
Confirming the same issue here.
valters wrote: Confirming the same issue here.
I'll check it for next release. I'm still on this stacking feature and requires lot of work. I can't make any release before making it workable.
momade
Thanks aoktar
Thanks aoktar
Can you make a settings with this sample scene? It's working as i can see here.
cnt.rar
(476.18 KiB) Downloaded 280 times
momade
Hey aoktar.
I changed the settings to produce the same masfunktion for both spheres.
please have a look. the counting texture should start running on frame 80.
zip is attached.
cnt_MO.zip
(438.19 KiB) Downloaded 274 times
valters
aoktar wrote: Can you make a settings with this sample scene? It's working as i can see here.
Beautiful test scene Ahmet :)
The issue is not with Movie Start Frame > Movie End Frame that controls Sequence it self but issue is with Range Start > Range End that controls when to start the playback and what to do with it
thanks
Return to “Releases”
