Version 2.24.1-R3 (06.10.2015) - obsolete stable
indexofrefraction
sent you a PM
and... thanks being here even on weekends for people's troubles! :)
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
MoGrafik
Not sure if it's come up already...Just reporting a problem I've just run into. I've got a pretty basic scene,but it crashes when I try to render with motion blur on? I had been using the 2.24.2 test, so I went back to this stable one, and it still does it.
Any suggestions?
Win 8.1 / i7 4930k / 2 x GTX Titan / Cinema 4d
MoGrafik wrote:Hi,
Any suggestions?
SUGGESTION: Please read how to post bugreports. It's on first page. Thanks.
mentor972
Just a note on the CUDA driver for Mac. We did have 6.5 or higher, but the engine would not do anything. Our theory is because of our simultaneous El Capitan upgrade. Once we upgraded to the newest 7.* Cuda Mac driver everything worked. So, basically somewhere between 6.5 and 7.* the CUDA driver will not work with this version on El Capitan. As long as you use the newest CUDA version it should fix your problem. (10/1/15 CUDA Update is what we upgraded to.)
fuchsundvogel
as i am a little confused where to post bugreports i mention it here aswell:
viewtopic.php?f=86&t=51036&p=254026
when i render with commandline and use the camera imager the render is darker
Equinoz
since 2.24.1 R1 the xparticles can't display on live viewer. I have enable the particle engine but it still not working
chouki
As said above ^^ about X-Particles :
With this version 2.24.1 the only way to see X-Particles in Live Viewer is to put a generator in X-Particles.
Example: you create an X-Particles setup, and asign an Octane material to the emitter. In version 2.24.0 it worked, particles were rendered by Octane. Not with this one, unless you generate geometry from XP, wich can become very heavy in polygons.
So I'm back to 2.24.0, too bad, I originally switched to 2.24.1 because of the crash when putting a material in the Local DB.
macOS 12.3.1 / C4D 2023.1 / M1Max MBP / 64Gb UM
chouki wrote:As said above ^^ about X-Particles :
I'm not working on this version. I'm trying to make a stable version from 2.42.2 TEST version. It has all features you say.
chouki
Great to hear that. I have no doubt you guys are working hard to make everything stable! cheers
