Version 2.23.2 - R6.2 (15.07.2015) - Obsolete stable
augdalmo wrote:Hi Aoktar,
I have download and installed R6 plugin, as I start C4D a warning messege appear "Impossible to start the program becouse "octane.dll" isn't on your computer.
This file is inside the folder "Libs64_200" in the plugin folder.
If I install R5 it works.
Win 8.1 64 bit C4D R16.050
EDIT: Hopefully that's fixed. Sorry for confusion
TBA3D_70
The newest 2.23.2_R6 OS X 64 (commercial) version not loading , also.
Elvissuperstar007
It does not update the camera
Elvissuperstar007 wrote:It does not update the camera
I'll check it but don't use octane dialog with Live Viewer. Just use Live Viewer
TBA3D_70 wrote:The newest 2.23.2_R6 OS X 64 (commercial) version not loading , also.
Are you using 16.050 as i indicated?
miohn
Hi Ahmet,
works fine here on Win 7 64!
Thanks much for adding the "disable node" function!
Just one question:
Is it possible to assign a shortcut (maybe spacebar f.e.)
to toggle a node on and off?
thanks
Mike
miohn wrote:Hi Ahmet,
Just one question:
thanks
Mike
Hopefully yes but on next versions. Enjoy it.
TBA3D_70
Yes i do.
Looking under the octane tab in the c4d menu --> nothing shown inside the octane tab.
I´ve a octane layout inside c4d and when I choose this --> c4d crashed.
Best regards,
Thomas
Yes i do.
Best regards,
Thomas
I checked that's fine on me. What's you previous version which can work? Do you have a compatible cuda driver?
I have fixed the Camera update problem for usage of Octane Dialog. Latest version is 2.32.2 R6.1.
