OctaneRender® for Poser (Windows) - build 1.29 [OBSOLETE]
I don't know how but in the 1.28 version suddenly the material picker in the viewport has become a color picker for the white balance and I can't get it to material picker again. Restart octane or poser does not help
I have no idea what caused this. Only thing unusual I did was to change poser smoothing to octane smoothing in setup. But changing that back again does not help. Loading rendertarget from default did not help either
Wim, I wonder if the Config.XML file has more than one pick more enabled? Could you email me your Config.XML file pls?
A quick update:
1) The Cuda errors popping on Refresh with 1.28 has been resolved (thank Otoy for their help with this), and this fix will be in the next Octane release 1.29 - available very soon.
2) Animation texturemaps does not currently work - and the changes from Octane 1.21 onwards makes the method I was using to implement this invalid - so I will need to look into another way of implementing this function, which will take some time.
3) There have been some LiveDb issues reported, and this will be rectified in 1.29
4) The issue with saving renders to a folder with special filenames is fixed in the next release.
wimvdb
It turned out to be a user mistake
I had not realized there is now a white balance picker button on the viewport and I had mistaken that one for the material picker.
Problem solved
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
I have updated the installer at the top of this thread with:
1.29.0.19
- Fixed issue causing cuda errors when refreshing the scene
- Fixed issue where saving an image to a folder with special characters was not working
- Added cursors for the 3 different Viewport pick modes
- Fixed issue where focus, material and white balance picking was not working correctly if the Viewport had been zoomed out
* Animating with image sequences is not currently working (and it will not be a 'quick fix' to get it working - sorry)
* Left-mouse button dragging the Viewport to pan when the resolution is locked is not currently working (and has potentially not working since focus picking was added)
In order to ensure downloading of LiveDb materials is working correctly, pls delete all files in the following directory:
C:\Users\[username]\AppData\Roaming\OctaneRender\cache
ch0pper
use poser material ambient_value for emission power when ticket
on the animation screen tab
comes back with this error.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1334, in EventRenderAnimation
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3231, in setEmitterValues
poser.error: Named actor could not be found
i am using poser pro 2014 but do have Pro 2012 also installed
ps using 129.0.19 new build
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
This looks like an internal Poser error. "poser.error: Named actor could not be found" means Poser couldn't locate the item you had as an emitter. Is there just one emitter in the scene? What sort of prop is it?
TRRazor
Kudos for material picking from the viewport !
I needed that ! :)
samhal
TRRazor wrote:Kudos for material picking from the viewport !
I needed that ! :)
What?! Material selection from the viewport? What did I miss?
Edit: Ah...must be part of .29.
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
This has been in the plugin for about 6 months!
samhal
6 months!! How the heck did I miss that!!!??!!
I'm not on my system at home at the moment, but is it a simple right click on the viewport or something?
Return to “Poser”
