Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
SVITAdmin
aoktar wrote:
SVITAdmin wrote:At least as a Team render node, the Mac's are working in Team Render. I have not tried using the Mac as the host computer yet however.
Got 12 Titans pumping out a scene right now from 2 PC's and 2 Mac's.
can you corfim the R15 for Mac is working smoothly?
I can confirm that Team Render on r15 Mac is working smoothly. I did notice you fixed the issue with the Edit Presets window. Thank you!
I'm going to do some tests with Mac workflow right now and will report back very shortly
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
uncia
Here is a video about activation problem on Windows 8 and Cinema R 15.
http://we.tl/casBkAxXlo
SVITAdmin: thanks, nice to know
uncia: looking for this problem...
SVITAdmin
OK. Just testing with some of the demo scene files and everything is smooth and quick. Seems faster actually.
Opening one of our work files, if i have the octane setup open, it will crash every time. If i load the scene and then open Octane setup, it's fine.
Also, the GPU's are not reporting percentage on live viewer on Mac. I assume it's because the OS does not report this info?
edited. added bug report
_BugReport.zip
(17.81 KiB) Downloaded 246 times
SVITAdmin
OK. On Mac, now i cant open any of my work files without a crash with or without octane setup showing
uncia wrote:Here is a video about activation problem on Windows 8 and Cinema R 15.
ok, can't see any crash that you said about octane dialog. Btw, new logic is that. If you close octane dialog plugin will stop, is this a BUG?
SVITAdmin wrote:OK. On Mac, now i cant open any of my work files without a crash with or without octane setup showing
hmm, for R15 on mac? can you try with R14 on mac?
SVITAdmin
crash on r14 version as well. every one of my work files
hmm, can you check for on new files? Also would you send me bugreport?
SVITAdmin
i attached a bug report a couple posts back.
Octane Demo files sometimes crash it and sometimes now.
At least Team render works.
I need to put .96 back on r15, but i'll leave .99e on r14 for if you need ant new info, but it's definitely not stable yet on Mac.
