Beta 0.72 / 0.79 (SDK 1.20) - Obsolete
indexofrefraction wrote:just a question... i have an interior shot with some sunlight coming in.
i wanted to boost the light a bit, so i made an extra light rectangle outside the window
i made it invisible and that works of course, but it blocks off the sun light coming from behind.
it seems an invisible area light still casts shadows coming from other light sources.
is there any solution to that? no comp tags there, right?
kernel->alpha shadows on
Sc4rfy
It' a problem of low memory or a problem of plugin? Because it's say that i have occupied 1 gb of 1,5 gb (gtx 480) but crash almost always
Win 10 64 Bit | i7 930 | 12 Gb Ram | GTX 760 |
do you have one gpu? If so renderer and C4D opengl share same memory. This will not give lot of space for rendering. You can try with software opengl to see difference
Silverwing
I really hope you get the animation problem fixed. I get about 30-50 frames then it stops. I have the latest version. Very nice for stills but not so hot for animation.
I think it might be a memory leak.
I have just rendered a few animations with several hundred frames. With every frame the RAM usage increases slightly. After 200 frames of rendering I had roughly 20 GB Occupied by C4D / Octane.
And its not the Picture Viewer frame cache. I cleared the cache there and it only dropped 1-2 GB.
Raphael
WIN 10 PRO 64 | ASUS X99-E WS | 3 X GTX 1080Ti | i7 5960X 8X 3,33GHz | 64GB RAM
Raphael
Hey,
i have fixed this. this is development release, you can try until next release
http://render.otoy.com/customerdownload ... 4-0.77.rar
dinf
Yes, this is working very well. Thanks again for your fast and effective code work.
| Win 10 | 64 GB RAM | AMD 5900X | RTX 3080 12 GB| C4D 21| C4Doctane v2022.1.1|
cyartist
Hi Aoktar,
Is there a r13 version of this latest version?
cyartist wrote:Hi Aoktar,
Please use other files and replace plugin from this file,
http://render.otoy.com/customerdownload ... 3-0.77.rar
cyartist
Thanks...much appreciated. Will test it out.
lilbignik
And what about R14-0.77?
Found. Sorry :roll:
Sorry for my English
Win 10 x64 / amd fx-9590 5.0Ghz / 3xGTX Titan Black 6gb/ 32gb / ArchiСad 19 / Cinema4D R17 / latest Octane.
