i roeland i been used the version 2.49
thank you
i add image
th first image have noise too, why ? with the same verision 2.49, the glass in the picture is good, in the new version i can't do that, a really glass, look so dark
OctaneRender® 1.025 beta2.57 release [obsolete]
- Przytulanka
Helo,
I made a simple urban model in Sketchup7, and when I open it in this release of Octane, i don't have any top of boxes (and roads, paths, colors and almost any things on a surface).
And what is the most annoying, in the last release which i had (it was 2.45 I think) it looks better - it didn't show roads, but all boxes were ok.
What's the problem with this release?
OS Windows 7 x64 l Sketchup Pro version 7.0.8657
AMD Phenom II X4 955 BE l GPU GeFroce GTX 285 1GB l 4 GB RAM
DRIVERS: nVidia 260.99 l CUDA 3.02
Rendering very big perfectly horizontal or vertical axis-aligned surfaces doesn't work correctly in Octane. In 2.55 we changed to a faster geometry intersection method, which has slightly less precision. This has somewhat exacerbated the problem.
You can work around this problem by importing the geometry on a smaller scale.
Roeland
Roeland
- LudovicRouy
- Contact:
+1 Yes it could be great to split the main rendering window on my second monitor ! until that i must resize on both screen but they aren't size identical (4/3 and 16/9) so i lose some usefull space
- fabiodamico
2:57 octane render does not work
linux ubuntu 12? how can I do?
- fabiodamico
you've installed the CUDA drivers ....
screenshot of the software opens, but then nothing happens ...
excuse my English...
- mib2berlin
Hi fabiodamico, you need a nvidia cuda driver 295.20 or newer.
This should be possible with the software management in ubuntu.
And the cuda toolkit from nvidia, you have to install by yourself with
http://developer.nvidia.com/cuda-toolkit-40
Cheers, mib.
sudo sh cudatoolkit_4.0.17_linux_64_xxx.runCheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
