Cinema4D version 2022.1.1-R6 (Obsolete stable) 08.07.2023
J.C wrote:
aoktar wrote:
J.C wrote:Here is video with the issue and C4D file I used to illustrate this.
refresh issue.mp4
update issueC4D.zip
Have you evert tried to do in a Standard layout or docked managers?
Yes, in this scene and other with Octane light it always happens when clicking the Octane light.
Send me your scene please
J.C
I've sent it last time with the video. Here it is again If you missed it.
update issueC4D.zip
(79.02 KiB) Downloaded 112 times
System – Windows 11
jayroth2020
@baghabanikm, make sure you have the ACES tonemap option enabled in the Octane Camera tag > Camera Imager tab.
SSmolak
baghbanikm wrote:
SSmolak wrote:
baghbanikm wrote: i mean's in my Live Viewer ACEs applying on render
but when I render, it doesn't apply
Look here : viewtopic.php?f=85&t=81434&start=80#p423754
Enable OCIO color in Project preferences and Image Viewer.
thanks a lot , but it doesn't my question's answer
i don't use OCIO . just i'm use the Aces Tonemapping Octane Camera's checkbox.
and Aces Tonemapping doesn't Apply on final render saved
C4D needs to use its own OCIO color management in Project Settings to show correctly ACES ( or other OCIO ) in C4D Picture Viewer.
jayroth2020
J.C wrote:I've sent it last time with the video. Here it is again If you missed it.
We haven't see this behavior in our systems or heard from others. Reset your C4D prefs to let our preferences are default and try again. Defaults are well, be sure you don't have something else to bug us.
J.C
Still happens after resetting settings, both on my system and my friend's system too. I've checked also with Cinema S24 and 2023.1 and 2023.2
System – Windows 11
As I said try to test it with default layout. For example, Texture UV dialog is setting dirty flags when it is open.
cirasa
in the 2022.1.1-R5 (Cinema4D 2023) I'm not able to save render pass anymore.
I had to switch back to 2022.1.
Anlv
cirasa wrote:Hi,
I encountered the same issue, and I changed the "Plugins" directory to lowercase "plugins" as prompted. Then I deleted all the xdl64 files except for "c4dOctane-R2023.xdl64". After that, I was able to perform multi-channel rendering normally.
PS: There is a hotfix version for 2022.1.1-R5, which you can download from the website.
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
