Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
zacknmotion
Great job on the new UI buttons! Octane is looking fresh as ever!
oblivion
Woooh :-) nice update!! Modern UI and I really like the search function in the node editor. So much faster now
Thanks Aoktar :-)
divasoft wrote:Please take a look. This problem now arises in osl textures and volumetrics. Vertical or horizontal artifacts. Is this a core or plugin issue?
https://yadi.sk/i/FY_FrDagYOFYrA
open, check in SA. It's core issue if it's same in SA
helloarty
Maan, Vectron Mandelbulbs still disappear when you trying to scale it, and bounds cut doesn't work. It was all good in 2019 release!
helloarty wrote:Maan, Vectron Mandelbulbs still disappear when you trying to scale it, and bounds cut doesn't work. It was all good in 2019 release!
something wrong with z_bound. drop me PM with version info, so I can give you quick build
franchais
I can't light my imported vdb volume with octane light. It's working with octane daylight
Link to my file.
https://we.tl/t-dOEs8uwNDU
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
eyeonestudio
Can't "ACES Buffer" and "Denoised Beauty Pass" be used together?
Octane Render Setting > Main > Render Buffer Type : Linear ACES2065-1
Use Denoised Beauty Pass : On
ACES File Name : Set
franchais wrote:I can't light my imported vdb volume with octane light. It's working with octane daylight
Link to my file.
everything seems to work as expected with your vdb file:
ciao Beppe
frankmci
SSmolak wrote:StrNotFound in File menu :
I've been seeing that for ages, through various versions, and I think I reported it here in the forums at one point. It's been long enough that I don't even notice it any more. :) It doesn't seem to be hurting anything.
Some little improvements on Nodes
