Oh thanks i ll w8 for it.
Btw quick test of viewport rendering is awesome! May i also ask about camera imager order: what is the choice here for having octane behave like in prev versions (with its own luts that is)? thanks a lot man, great release so far
Version 3.08.1-R4 (obsolete stable)
It was mistakenly added in options of previous version. It's not a part of V3.mpazera wrote:I can't find universal material in 3.08.1-R2
Could you please send me this vdb?thanulee wrote:Two more things that need fixing (i guess are already known from other users feedback) :
a) glossy icon is same as specular icon
b) vdbs dont show correct in viewport (see image below)
U need the exact vdb file i used? Ok i ll remake scene tomorrow and send it, thanks
I have some issues with 3.08.1-R2.
I tested different nvidia drivers but had no success. IPR works fine but when starting even a simple render with a spinning cube, octane renders frame 0 and the stops. When closing the PictureViewer Cinema does not respond and i have to kill it in task manager. I also tried different projects. I had to go back to 3.08-RC3 to get my jobs done. Now i'm on 390.77. The newer one showed cuda errors in octane log.
Cinema is on 18.057.
Any idea what could cause the stable version to behave like this?
Greets
Greets
Win 10 64 | 2x RTX 3080Ti 2x Xeon E5 2650v2 Supermicro X9DAi 128 GB
Win 10 64 | 1x RTX 4090 i9 9900K Gigabyte z390 128 GB
Win 10 64 | 2x RTX 3080Ti i7 2600 K 32 GB
Try clean installs and be aware of Win10 problems. You need a stable setup for stable gpu rendering.fibernaut wrote: Any idea what could cause the stable version to behave like this?
Greets
Hi, i got a scene that crashes on first frame. Here is the bug report. Its just a statue. It also crashes when i try to save no matter format or size in a scene with a single cube. If i dont press "save beauty" it just stucks on the 2nd frame forever... Thoughts?
edit: this happens in R18 but not in R19 (which is a clean install atm with only octane. maybe some plugin conflict of some short?)
- Attachments
- _BugReport.txt
- (313.11 KiB) Downloaded 287 times
