OctaneRender™ 2020.1.3 for Blender® 2.83 - new free tier!
allanmrtn3
Can I import an orbx from standalone into OctaneBlender? I tried importing via the node graph but it doesnt show in Blenders viewport.
Is it possible at all?
J.C
allanmrtn3 wrote:Can I import an orbx from standalone into OctaneBlender? I tried importing via the node graph but it doesnt show in Blenders viewport.
You can load an ORBX file but you can't edit it. Here is how:
Add a simple 3d object that will work as a placeholder for the ORBX file. Go to it's Object data Tab > Octane properties > at the bottom there will be a file input for ORBX file you can load > start render to see a ORBX file.
System – Windows 11
planktongroup
Hi all,
love octane in blender!
I have a problem with the passes, they don't seem to work. All are displaying as black.
Anyone have an idea why it might be?
Would appreciate your help.
Cheers
DrachenSeele
Hello,
I have a question regarding the download of the OctaneServer for this free tier. I've looked throu the comments but didnt find any link to the 20.1 version of the Renderer
Badger
I'm having a problem with the View/Render layers rendering node via compositing. It seems only one render/view layer renders from the animated camera, all the others render from a viewport perspective. Anybody else had this problem?
creb
Hi All
I am new in octane,
I get problem with render preview is much brighter than final render, maybe 3 times brighter, how i can fix this and i can find material preview in material section.
Thanks for helping me
my PC i5 4570 16GB RAM 1070ti 8GB VRAM
creb
creb wrote:Hi All
I am new in octane,
I have my own solution after some test. I set none in color managemet display device, check octane camera imager in camera section and set response type to linear/off
hope it help
Sanekum
How can I exclude Cube objects from casting Dirt?
Corona can do that easylly with Include\Exclude object node
olawson
Thanks so much for this, everything has been working fine for me.
Are there any plans to add string widget="popup" OSL support for Blender?
J.C
creb wrote:Hi All
I am new in octane,
Hello, you have to disable Blender's color management and enable Octane Imager if you you want to match preview and final render.
Set Display device to none and Look to none in Color management panel.
System – Windows 11
