Can I import an orbx from standalone into OctaneBlender? I tried importing via the node graph but it doesnt show in Blenders viewport.
Is it possible at all?
OctaneRender™ 2020.1.3 for Blender® 2.83 - new free tier!
You can load an ORBX file but you can't edit it. Here is how:allanmrtn3 wrote:Can I import an orbx from standalone into OctaneBlender? I tried importing via the node graph but it doesnt show in Blenders viewport.
Add a simple 3d object that will work as a placeholder for the ORBX file. Go to it's Object data Tab > Octane properties > at the bottom there will be a file input for ORBX file you can load > start render to see a ORBX file.
System – Windows 11
System – Windows 11
- planktongroup
Hi all,
love octane in blender!
I have a problem with the passes, they don't seem to work. All are displaying as black.
Anyone have an idea why it might be?
Would appreciate your help.
Cheers
Cheers
- DrachenSeele
Hello,
I have a question regarding the download of the OctaneServer for this free tier. I've looked throu the comments but didnt find any link to the 20.1 version of the Renderer
I'm having a problem with the View/Render layers rendering node via compositing. It seems only one render/view layer renders from the animated camera, all the others render from a viewport perspective. Anybody else had this problem?
Hi All
I am new in octane,
I get problem with render preview is much brighter than final render, maybe 3 times brighter, how i can fix this and i can find material preview in material section.
Thanks for helping me
my PC i5 4570 16GB RAM 1070ti 8GB VRAM
I am new in octane,
I have my own solution after some test. I set none in color managemet display device, check octane camera imager in camera section and set response type to linear/offcreb wrote:Hi All
I am new in octane,
hope it help
Hello, you have to disable Blender's color management and enable Octane Imager if you you want to match preview and final render.creb wrote:Hi All
I am new in octane,
Set Display device to none and Look to none in Color management panel.
System – Windows 11
System – Windows 11
