OctaneRender 2 for Poser (Windows/OSX) [OBSOLETE]
Andygraph3D
windows 64bit
graphic card quadro 2000 dvi
Nvidia drive v340.52
Poser 10.0.3.26510 x86 (32bit)
windows 64bit
I believe that if you have a 64 bit Windows OS, you need to install the 64 bit version of the Poser plugin (even if you are using 32 bit Poser).
Andygraph3D
ok i have uninstall 32 bit plugin and installed 64bit (the installer anyway search Poser pro 2014 in program folder and no in (x86) programs folder)
but when open poser i see this error
An errror occurred importing addon OctaneRender for Poser :
ERROR: [Error 2] Impossibile trovare il file specificato: u'C:\\Program Files (x86)\\Smith Micro\\Poser 10\\Runtime\\Python\\addons\\OctaneRender for Poser\\2-32'
if i try to install 32 bit octane plugin 1.5 all work fine ...
You are right.....I will investigate the problem.
Andygraph3D - I have refreshed the 32 bit installer, which should now resolve the problem you were having. Can you pls re-download and install the 32 bit version of the plugin.
Andygraph3D
fixed it (i have delete the old plugin addons folder and reinstalled all) but i need try it on my pc studio for now i have try with home pc .. check it soon
the plugin dont found the splashscreen:
12:07:38 PM: Can't load image from file 'C:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\addons\OctaneRender for Poser\splash_mini 2.png': file does not exist.
12:07:38 PM: Can't load image from file 'C:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\addons\OctaneRender for Poser\splashscreen 2.png': file does not exist.
Andygraph3D
when open poser i have again this message:
This pz3 file was saved with prior version of OctaneRender for Poser, and save of the saved setting may not be compatible with the current plugin version.
when open render octane panel i see this message
7:23:19 PM: Can't load image from file 'C:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\addons\OctaneRender for Poser\splash_mini 2.png': file does not exist.
7:23:19 PM: Can't load image from file 'C:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\addons\OctaneRender for Poser\splashscreen 2.png': file does not exist.
when try to open the "Open Viewport" the windows is black
when try to change the texture enviroment i have this message:
"the video card does not apper to be responding. Reset The Card"
so i have try to open octane and import a obj file.. and octane work fine.
Andygraph3D
render black fixed .. just i have reset/apply the cuda devices ;-)
bu i have problem again with first error message about pz3 setting..(maybe i need delete old rendertarget setting, where i found it ?) and error about splash_mini 2.png, splash_mini 2.png, splashscreen 2.png
Andygraph3D - I have refreshed the 32 bit installer, which should now resolve the splash_mini 2.png, splash_mini 2.png, splashscreen 2.png problems. My apologies for the error - you are the only person using the 32 bit version, so the installer has hard some issues.
LuvMultimedia
I have tried various skin textures in Poser on V4 and no matter what I do the skin textures will not show up in my Poser Octane renders. Everything else will load but not the skin texture. Can someone give me a step by step on how to get skin textures to load and render in Poser octane please? My email is [email protected] ...
WIN 10 64 | Geforce 970| 16 GB
Return to “Poser”
