Cinema4D version 2021.1.7 (Old stable) 16.12.2022
thanulee
Hello I cannot render TFD cached sims anymore.
I dont know what happened it was working ok. I tested r23, 2023, s26, 2023.1 none of them work. From 2021.1.5 to 2021.1.6 octane. I am using 512.59 drivers
Scene file: https://www.dropbox.com/s/m30yxbx2f0cuxzy/tfd.c4d?dl=0
edit: TFD dev confirmed a bug on his end
SSmolak wrote:
aoktar wrote: It requires some converter functions to work with that. I haven't yet got some time but it's on table.
Great. Just asking. I know that there are more important things to do :)
Disable OSL node cause that all tree is disabled too :
It's not easy to know which node should be connected
seangoodsell
Did you guys have a solution to the crash when trying to move an area light in a blank scene?
SSmolak
aoktar wrote: It's not easy to know which node should be connected
But this is only OSL node issue. All other works fine - nodes that are connected to disabled node works as expected.
dasmodular
Hello,
I updated to the latest Plugin from R4 to R6 and now the textures are all black when rendering an animatic in OpenGL view.
I tried to deactivate the fast texture loading und cleared the texture chache, but that didn't help.
I returned to R4 and it works again.
Best regards,
Denis
J.C
Why there is two GPUs limit on Studio version? I have Studio+ subscription.
System – Windows 11
J.C wrote:Why there is two GPUs limit on Studio version? I have Studio+ subscription.
Which version are you using?
J.C
I'm using
WINDOWS SUBSCRIPTION(Studio) BUILD
System – Windows 11
J.C wrote:I'm using
using it but 2021.1.6 or 2022.1?
J.C
Latest 2021.1.6-(R7) downloaded here from post #1
System – Windows 11
