Version 2.12.2 - final (updated on 18.11.14)
miohn
thanks brasco!
Mike
used2bgordy
My Cinema R15, crashes after just some time, either while working or sitting idle.
Here's bug report. Help?!
Artur
_BugReport.txt
(351.08 KiB) Downloaded 344 times
used2bgordy wrote:My Cinema R15, crashes after just some time, either while working or sitting idle.
Artur
do you have more bugreports? It's not usual the crashing without doing anything.
What's your gpus, drivers?
used2bgordy
GPU:
- 780 TI
- 660
Drivers: 335.23
It seems Cinema overwrites previous bugreports
Artur
used2bgordy wrote:GPU:
- 780 TI
- 660
Drivers: 335.23
Artur
Can you backup and send me these?
nienieskiem
Object Buffer option is very important needed function,
would be very nice if it worked again in 2.11.2 version
(sorry about my english)
atome451
I think i've found a little bug:
In passes rendering, if you choose TIFF format, all passes are wrong. With PSD format, the result is ok. I didn't tested other file formats.
Cinema 4D R14 - Version 2.11.2
The log doesn't show something special but with the TIFF format, the time of passes saving is longer.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
used2bgordy
- 780 TI
- 660
Drivers: 335.23
Artur
You mean bugreport? Because I attached one in the first post.
Chriz
Hi. First: Thank u for the great plugin and all the updates with nice features!
i just realized that the objectupdate seems not work in R16? I just took a cube, put a octane-objecttag on it and tried to liverender while moving the box.
Same simple setup in R15 works!
Octane 2.11.2 / Standalone 2.12.1/ Win 7 64bit / R16 / Nvidia driver 335.23
Thanks for your work!
Chriz
http://www.C9W.de - Win10 - Dual E5 2620v3 - Display 1 GTX 1080 / Render 1 3090 RTX - 96 RAM - C4D MSA - C4D Plugin version: current - Standalone: current
Native c4d passes have been disabled. We will replace "Object buffer" with Octane's new implementation. Please do some work-around until it come up.
For bugreports, please try to add a sample scene for me. Otherwise, hard to reproduce same problems here.
