thanks brasco!
Mike
Version 2.12.2 - final (updated on 18.11.14)
- used2bgordy
My Cinema R15, crashes after just some time, either while working or sitting idle.
Here's bug report. Help?!
Artur
Artur
- _BugReport.txt
- (351.08 KiB) Downloaded 318 times
do you have more bugreports? It's not usual the crashing without doing anything.used2bgordy wrote:My Cinema R15, crashes after just some time, either while working or sitting idle.
Artur
What's your gpus, drivers?
- used2bgordy
GPU:
- 780 TI
- 660
Drivers: 335.23
It seems Cinema overwrites previous bugreports
Artur
- 780 TI
- 660
Drivers: 335.23
Artur
Can you backup and send me these?used2bgordy wrote:GPU:
- 780 TI
- 660
Drivers: 335.23
Artur
- nienieskiem
- Contact:
Object Buffer option is very important needed function,
would be very nice if it worked again in 2.11.2 version
(sorry about my english)
I think i've found a little bug:
In passes rendering, if you choose TIFF format, all passes are wrong. With PSD format, the result is ok. I didn't tested other file formats.
Cinema 4D R14 - Version 2.11.2
The log doesn't show something special but with the TIFF format, the time of passes saving is longer.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
- used2bgordy
aoktar wrote:Can you backup and send me these?used2bgordy wrote:GPU:
- 780 TI
- 660
Drivers: 335.23
Artur
You mean bugreport? Because I attached one in the first post.
Hi. First: Thank u for the great plugin and all the updates with nice features!
i just realized that the objectupdate seems not work in R16? I just took a cube, put a octane-objecttag on it and tried to liverender while moving the box.
Same simple setup in R15 works!
Octane 2.11.2 / Standalone 2.12.1/ Win 7 64bit / R16 / Nvidia driver 335.23
Thanks for your work!
Chriz
Chriz
http://www.C9W.de - Win10 - Dual E5 2620v3 - Display 1 GTX 1080 / Render 1 3090 RTX - 96 RAM - C4D MSA - C4D Plugin version: current - Standalone: current
Native c4d passes have been disabled. We will replace "Object buffer" with Octane's new implementation. Please do some work-around until it come up.
For bugreports, please try to add a sample scene for me. Otherwise, hard to reproduce same problems here.
