Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
SVITAdmin
aoktar wrote:Hi,
a video for TeamRender support of R15. It seems smoothly working
[vimeo]http://www.vimeo.com/79464295[/vimeo]
Interesting. is it necessary to overwrite kernel settings for this to work?
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
no need
dinf
How did you get the clients to work? In R14 netrender one needs C4D pluign *plus* full Octane standalone per client. Will there be a different solution? I saw a typical demo overlay in some pictures here.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
dinf wrote:How did you get the clients to work? In R14 netrender one needs C4D pluign *plus* full Octane standalone per client. Will there be a different solution? I saw a typical demo overlay in some pictures here.
it's done very easy and i did in first try. Only need a R15. I keep open a Cinema4d on client and server found it. you haven't to copy textures, C4D does it for you.
artdude12
Just to clarify, just need to have R15 Team Render on each client Or R15 Team Render + Octane C4d plugin on each client?
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
artdude12 wrote:Just to clarify, just need to have R15 Team Render on each client Or R15 Team Render + Octane C4d plugin on each client?
yes you need second plugin for other machine
krzychuc4d
is it working with octane c4d plug 0.96 or next plugin release ?
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
krzychuc4d wrote:is it working with octane c4d plug 0.96 or next plugin release ?
no, it's new for wip version.
SVITAdmin
A note about team render for when this build or final build becomes available. It works amazingly great. However, if you are using HOT4D, or TurbulenceFD (with the workaround) on the host machine, Team render will not work. I'm sure there are other plugins that will crash it. One thing i have noticed about these two particular plugins, is that they require files to be in the root C4D folder. Not sure if that is the issue. This only seems to be an issue with the host computer. The render nodes seem to not be affected.
These plugins are not an issue if you are rendering on just one machine (not Team render)
Pumping out a 2k sequence right now on two PC's with 4 Titans each. TR is flying through it. :D :mrgreen:
dinf
aoktar wrote:yes you need second plugin for other machine
Thanks, that was my question :)
Are there planned special priced client packages therefore in the future, like '5 TR clients for 150' or something like that?
