nice. This option decrease gpu usage and render performance. You can try different option as "low, medium or high".dinf wrote:With "Use pri." activated all smooth and so far no "devices dev:0" info, without all windows moving in steps.aoktar wrote:can you test to drag some windows while rendering? can it be smoothly moved?
Beta 0.72 / 0.79 (SDK 1.20) - Obsolete
Hi Aoktar,
Since the standalone has background images and r14 has the camera calibrator, what would you think about implementing a combination of those two? Is it even possible? I think it would make many users very happy...
I have been trying to figure out a way to use either one but have not found a way yet.
- mattfrodsham
- Contact:
I would certainly appreciate a 'BG image' solution for lining up/matching lighting to a background plate during tests. Am I correct in thinking the only way to do something like this is with a spherical HDR?
Also I know it has been asked many times but a compositing tag would be fantastic.
Sorry for the ignorance but is there a public roadmap to stop me requesting things that are already being worked on?
Windows 8.1 / 4xGTX980 / C4D R18
Live viewer can show background and foreground images, but it's not finished completely. I'll finish this after node editor became useable.mattfrodsham wrote:I would certainly appreciate a 'BG image' solution for lining up/matching lighting to a background plate during tests. Am I correct in thinking the only way to do something like this is with a spherical HDR?
- Silverwing
- Contact:
Hi aoktar,
Just want to check back if you have noticed by post on PAGE 13
Because you didn´t respond to it!
Raphael
Raphael
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
yes, this is right. Colors are squeezing to 8bit.Silverwing wrote:Hi aoktar,
Raphael
- mattfrodsham
- Contact:
Fantastic news, thank you!aoktar wrote:Live viewer can show background and foreground images, but it's not finished completely. I'll finish this after node editor became useable.mattfrodsham wrote:I would certainly appreciate a 'BG image' solution for lining up/matching lighting to a background plate during tests. Am I correct in thinking the only way to do something like this is with a spherical HDR?
I have tried to animate a building exploding with fracture in c4d and it works great in just c4d but not in octane, I have used an octane object tag and assigned a number on the fracture (I also tried it on everything else as I'm a noob) also update geometry is checked.
Is it possible?
As I said I'm just learning so any pointers appreciated.
I can use hot4d in same way in octane and animate an ocean so I was surprised I couldn't get it to work.
Craig.
Ps if anyone is interested I'm working from this great tutorial I found.
http://jamie3d.com/exploding-things-wit ... -cinema-4d
R14 Broadcast i7 2x gtx780 windows 32gb
Is it possible?
Craig.
i think that you mean realtime update feature is not working on fractured objects. I must check this. Propably plugin don't understand there is a change on this objects. A little trick to put a animated null object inside this group.Elprezzy wrote:Hi,
Is it possible?
As I said I'm just learning so any pointers appreciated.![]()
Craig.
