OctaneRender 3 for DAZ Studio [TEST and STABLE] [OBSOLETE]
Moderator: BK
zx13275744718
face_off wrote:Attached is a highly experimental release which tries to fix the problem reported above by Rajib. I found it worked well when loading new scenes, but I got mixed results when Merging scenes.
3.5.0.30
- Compiled with Octane 3.05
- Added support for Instances Groups - so UltraScatter and Voxelizer scenes should now work
- Fixed issue where loading or merging a scene whilst the current scene is rendering would cause the Octane Viewport to step rendering in some situations - requiring a DAZStudio restart
https://render.otoy.com/customerdownloa ... _Win64.exe
That mean we can import VDB file in DAZ STudio? How to use it?
3.5.0.30
A reasonably important issue has been reported on this build - so I have removed the download link. Hopefully I will have a solution and a new build in the next day or two.
There is no means to import VDB files into the plugin. Instead, you can export from the plugin to OCS and load into Octane Standalone and add VDB files there.
While testing the experiential release (3.5.0.30) I have found another issue that has been there before in all the release. It is something to do with the local or world transform I think.
Thanks Rajib - I will investigate.
rajib
Hi Paul,
Have found a serious bug in the 3.5.0.30 experimental version. I am loosing all Rendersettings, Environment settings and Octane material previously saved with the scenes if I double click on any previously saved materials presets under Daz with the Octane materials set. When I double click on them (under the Content Library pane) to load the materials, the plugin is closing the Octane Viewport (if open) and not only the Octane materials is not getting loaded (it defaults to the Daz materials), but it is again resetting the Render Settings and Environment settings changes I had done on the scene.
To repeat the issue:
1. Create a scene and put a cube in it.
2. Go to Rendersettings tab and change some of the values.
3. Go to Environment tab and changes some of the values.
4. Go to Materials tab and apply any Octane material from the Live DB to the cube.
5. Use File->Save As->Material(s) preset to save the cube material.
6. Using Content Library pane, go to the material preset folder and double click on the material present you saved in step 5 to apply it again on the cube.
If the Octane viewport was open it will close, you will see the values in the Rendersettings and Environment tabs have reset to the default value. Also in the Materials tab, the Octane materials that you saved and applied on the cube are no longer there and the cube has the Daz material.
Regards,
Rajib
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
Thanks Rajib - yes, I found that too and removed the downloaded link (see me msg above). I think I have found a solution - but still testing.
TRRazor
Should any of the RedSpec-SSS-using folks out there have downloaded the experimental build, we strongly advise to not use it with our shaders.
The error described above by rajib, pretty much causes the shaders to not function correctly.
Please roll back to the last TEST build in order to correctly use the shaders again - Thanks.
RGUS
TRRazor wrote:Should any of the RedSpec-SSS-using folks out there have downloaded the experimental build, we strongly advise to not use it with our shaders.
Yeah... I did... done!
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.80 Prime
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Fanthomas
Live DB material materials can not be partially loaded!
Some materials can not be loaded from the LiveServer, then the load window remains open and you can do nothing more - neither close the window nor save the scene. The only way to strangle the program in the task manager. If you have not stored there before all work is gone!
It would be great if you could close this window or fix the defective materials. ("Metal Dirt" is a material that does not work, but there are several)
Greetings Thomas
R3.4.5.29
Motherboard Model:MSI X99A SLI PLUS(MS-7885)
Processor Name:Intel Core i7-5820K
Total Memory Size:32 GBytes
Video Chipset:2X NVIDIA GeForce GTX 970 4GB
GeForce Game Ready Driver Version: 376.33
garand3d
Live DP material materials can not be partially loaded!
Confirmed. This has happened to me a couple of times too. Is canceling the liveDB loading process theoretically possible? Perhaps Paul can devise a workaround...
Win 10 Pro 64bit | 2 x ASUS GTX TITAN BLACK, 6GB GDDR5 | Intel Core i7 3770K, 3.50 GHz | 32 GB RAM
MSI GT83VR SLI 7RF | Win 10 Home | 32 GB RAM
DAZ Studio Pro 4.10.0.123 | OR S.A. V3.01.1b | OCDS V3.8.2.39 | GeForce Driver 398.36
AlfaseeD
Hi Paul,
I just noticed that most of the latest product on Daz support iRay and their material most of the time use the metallicity/roughness maps.
Usually there are a few maps: metallicity map, diffuse, glossy, roughness and normal.
Now, the Octane plug-in doesn't seems able to convert this kind of shader and this is a really huge problem since I need to do it all by hand and yeah, it's super time consuming.
Do you plan to improve the material/shader conversion in order to get a good results in octane without the need to do it all by hand?
Hubby72
Hi AlfaseeD,
check these forum posts and you can make yourself a picture of the answer to your question :
viewtopic.php?f=44&t=57829
viewtopic.php?f=44&t=57905
Win 10 x64 | Zotac Geforce GTX780 6GB, Gigabyte GeForce GTX 960 | Intel Core i7 3770 | 32GB Corsair DDR3-1600 | PNY 480 GB SSD |
My Blog : http://www.subwaytotatooine.de/
My DA : http://hubby72.deviantart.com/
Return to “DAZ Studio”
