Version 2.16.2
I can't. I'm going to release 2.20 in a few days.garytyler wrote:Will you please provide this test with the slider update for Mac?
I duplicated this twice. 500 MB scene, running Live View and delete a protection tag on the camera = crash.
- Attachments
- _BugReport.txt
- (196.96 KiB) Downloaded 434 times
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
i think that's not a octane thing. If you have a scene which can reproduce the crashes in spesific steps, please let me know and try to send.garytyler wrote:I duplicated this twice. 500 MB scene, running Live View and delete a protection tag on the camera = crash.
Hello,
I never ever had any serious problem with octane until now
I have crash when I load HDRI, but very strange not every HDRI file only some of them.I try to create HDRI file with HDRI LIGHT STUDIO and everything works fine until I save file and immediately crash.
I have this message in log file :
Prefs:C:\Users\server2\AppData\Roaming\MAXON\CINEMA 4D R16_14AF56B1\prefs\oct.dat
Can't Read Preset File: C:\Program Files\MAXON\CINEMA 4D R16\plugins\c4doctanepresets.dat
I try on other computer but same thing, I use 1x titan black and 3 x 980 on each computer.
dat file in attachment
Thanks in advance
Cheers.
Thanks in advance
Cheers.
- Attachments
- oct.rar
- (369 Bytes) Downloaded 377 times
Product Designer & 3D Generalist
Windows 8.1 | 2X GTX Titan Black | 8 X GTX 980 | Intel Xeon | EVGA Classified SR-2 | 48 GB ECC RAM | 256 GTX Neutron SSD | X-Particle Pro 2.5 | Octane 2.16
- focusadvantage
I've got some issue with mac version of the plugin. Cinema crashes every time I try to paste object with octane material attached to it.
Every single time on every scene I've tried. I can copy only when octane is removed from plugins folder or delete material from object and then copy paste it separately. But there is another thing: when I paste object with material which has name already used in target scene then this material doesn't paste to target scene and material has been relink to that material already in the scene.
Is there a way to plugin rename material when pasting to the scene? For example if I've got material named "Glass" and paste object with another "Glass" one of the materials will switch name to "Glass_1"?
- Attachments
- _BugReport.zip
- (15.43 KiB) Downloaded 374 times
we need a bugreport.zip not *.dat file. This messages are not a serious issue. Macosx? What kind of hdri makes crashes?creatorz wrote:Hello,
Thanks in advance
Cheers.
can you give me a sample scene to reproduce here? I see a mix material causes this crashes.focusadvantage wrote:I've got some issue with mac version of the plugin. Cinema crashes every time I try to paste object with octane material attached to it.
- sparkworld
We are having some issues with octane crashing randomly during rendering on our computers. It seems that it often happens after one render has completed all its frames. The render queue seems to always crash between renders. Sometimes it even crashes in the middle of render. Could this be caused by the network cutting out? We are using Octane 2.16.2
We are working on a Mac Pro with a Titan Black as our primary rendering GPU. I'll attach the bug report from our most recent crash.
- Attachments
- _BugReport.txt
- (135.95 KiB) Downloaded 453 times
